WegaWin programından SQL ile cari bilgilerini çekme
Aşağıdaki kod bloğu ile cari bilgileri çekilebilir
SELECT
  F0101TBLCARI.IND,
  F0101TBLCARI.FIRMAADI,
  F0101TBLCARI.FIRMAKODU,
  F0101TBLCARI.FIRMATIPI,
  CASE
    WHEN F0101TBLCARI.FIRMATIPI <> 5 THEN (ISNULL(F0101TBLCARI.ADI, '') + ' ' + ISNULL(F0101TBLCARI.SOYADI, ''))
    ELSE F0101TBLCARI.YETKILI
  END AS YETKILI,
  F0101TBLCARI.PARABIRIMI,
  F0101TBLCARI.AYLIKVADE,
  F0101TBLCARI.GECIKMEFAIZI,
  F0101TBLCARI.VERGIDAIRESI,
  F0101TBLCARI.VERGINO,
  CONVERT(nvarchar(250), F0101TBLCARI.ADRESPOSTA) ADRESPOSTA,
  CONVERT(nvarchar(250), F0101TBLCARI.ADRESFATURA) ADRESFATURA,
  CONVERT(nvarchar(250), F0101TBLCARI.ADRESSEVK) ADRESSEVK,
  CONVERT(nvarchar(250), F0101TBLCARI.ISTIHBARAT) ISTIHBARAT,
  F0101TBLCARI.ISKONTO,
  F0101TBLCARI.KOD1,
  F0101TBLCARI.KOD2,
  F0101TBLCARI.KOD3,
  F0101TBLCARI.KOD4,
  F0101TBLCARI.KOD5,
  F0101TBLCARI.UNVAN,
    (SELECT
    REPLACE(CAST(SUM(ISNULL(F0101D0004TBLCARIHAREKETLERI.BORC, 0) - ISNULL(F0101D0004TBLCARIHAREKETLERI.ALACAK, 0)) AS DECIMAL(18,2)), '.', ',')
  FROM F0101D0004TBLCARIHAREKETLERI
  WHERE F0101D0004TBLCARIHAREKETLERI.FIRMANO = F0101TBLCARI.IND
  AND OZELKOD <> 'KREDIHESABI')
  AS BAKIYE,
  F0101TBLCARI.TELEFON1,
  F0101TBLCARI.PERSONELNO,
  F0101TBLCARI.SATISYAPILMASIN,
  F0101TBLCARI.TAHSILATYAPILMASIN,
  F0101TBLCARI.IADEFATURASIKESILMESIN,
  SUBSTRING(F0101TBLCARI.ISTIHBARAT, 1, 1) AS INFO,
  F0101TBLKREMUSCUZDAN.ESININADISOYADI,
  F0101TBLCARI.KREDILIMITI,
  F0101TBLCARI.RISKLIMITI,
  F0101TBLCARI.FIRMATAKIPKODU,
  F0101TBLCARI.EFATURAKULLANICISI
FROM F0101TBLCARI
LEFT JOIN F0101TBLKREMUSCUZDAN
  ON F0101TBLCARI.IND = F0101TBLKREMUSCUZDAN.MUSTERINO
WHERE (F0101TBLCARI.STATUS <> 2
OR F0101TBLCARI.STATUS IS NULL)
AND F0101TBLCARI.IND >= 100
AND (F0101TBLCARI.FIRMATIPI = 1
OR F0101TBLCARI.FIRMATIPI = 2
OR F0101TBLCARI.FIRMATIPI = 5
OR F0101TBLCARI.FIRMATIPI = 4
OR F0101TBLCARI.FIRMATIPI = 11
OR F0101TBLCARI.FIRMATIPI = 9
OR F0101TBLCARI.FIRMATIPI = 13)
AND FIRMATIPI NOT IN (12, 11)
Aşağıdaki kod bloğu da kullanılabilir
SELECT
TBLCARI.FIRMAKODU,
TBLCARI.KOD1,
TBLCARI.KOD2,
TBLCARI.KOD3,
CAST(TBLCARI.ADRESFATURA AS NVARCHAR(100)) as ADRES,
TBLCARI.FIRMAADI,
TBLCARI.TELEFON1,
TBLCARI.TELEFON2,
TBLCARI.YGSM,
TBLCARI.FAKS,MAX(TCG.TARIH) AS  SONISLMTRHI,
CASE WHEN TCG.PARABIRIMI IS NULL THEN  TBLCARI.PARABIRIMI  ELSE TCG.PARABIRIMI END AS PARABIRIMI,
DBO.ROUNDYTL(ISNULL(SUM(TCG.BORC / case WHEN ISNULL(TCG.KUR,1) = 0 then 1 else TCG.KUR end),0)) as BORC,
DBO.ROUNDYTL(ISNULL(SUM(TCG.ALACAK / case WHEN ISNULL(TCG.KUR,1) = 0 then 1 else TCG.KUR end),0)) as ALACAK,
(SELECT DBO.ROUNDYTL(ISNULL(SUM((BORC - ALACAK) / case  WHEN ISNULL(KUR,1) = 0 then 1 else KUR end),0))
FROM F0101D0001TBLCARIHAREKETLERI  WHERE FIRMANO = TBLCARI.IND and PARABIRIMI = TCG.PARABIRIMI AND 1=1) as BAKIYE,
DBO.ROUNDYTL(ISNULL(SUM(TCG.BORC),0)) as TOPLAMBORC,DBO.ROUNDYTL(ISNULL(SUM(TCG.ALACAK),0)) AS TOPLAMALACAK,
( SELECT DBO.ROUNDYTL(ISNULL(SUM(BORC - ALACAK),0)) FROM  F0101D0001TBLCARIHAREKETLERI
WHERE FIRMANO = TBLCARI.IND   AND PARABIRIMI = TCG.PARABIRIMI  AND 1=1   ) AS TOPLAMBAKIYE
FROM F0101TBLCARI as TBLCARI  LEFT JOIN F0101D0001TBLCARIHAREKETLERI as TCG on(TBLCARI.IND = TCG.FIRMANO)
WHERE(TBLCARI.IND >= 100)
AND TBLCARI.FIRMATIPI NOT IN(5)
GROUP BY  TBLCARI.IND,
TCG.PARABIRIMI,
TBLCARI.PARABIRIMI,
TBLCARI.KOD1,
TBLCARI.KOD2,
TBLCARI.KOD3,
CAST(TBLCARI.ADRESFATURA AS NVARCHAR(100)),
TBLCARI.TELEFON2,
TBLCARI.TELEFON1,
TBLCARI.YGSM,
TBLCARI.FAKS,
TBLCARI.FIRMAKODU,
TBLCARI.FIRMAADI
HAVING 1=1
ORDER BY TBLCARI.IND
